Robert
  • Topics: 1
Gear Position Sensor (Neutral Sensor) = Faulty or broken wires inside Or Clutch Switch handlebar has problem (actual switch or wire broken inside) Also if there is power loss at 1000-2000 rpm = Does it idle okay in standstill or when you idle , does the RPM needle jump up & down ?
At idle speed the RPMs jump to 1500-2000.
