Viewing 7 reply threads
    • #14540
      Robert
      GV 125s loses power at revs (2000), in 1st and 2nd gear. Above 5000 revs it is ok. Error P0850 – GP or Clutch lever Switch Circuit Malfunction was displayed.
      I corrected the contacts, the error is still there.
      Can anyone help?
    • #14549
      Gear Position Sensor  (Neutral Sensor) = Faulty or broken wires inside
      Or
      Clutch Switch handlebar has problem (actual switch or wire broken inside)
      Also if there is power loss at 1000-2000 rpm  = Does it idle okay in standstill  or when you idle , does the RPM needle jump up & down ?
    • #14552
      Robert
      Gear Position Sensor (Neutral Sensor) = Faulty or broken wires inside Or Clutch Switch handlebar has problem (actual switch or wire broken inside) Also if there is power loss at 1000-2000 rpm = Does it idle okay in standstill or when you idle , does the RPM needle jump up & down ?
      At idle speed the RPMs jump to 1500-2000.
    • #14553
      At idle Does it stay 1500 rpm ?  ==== > or  does it do this   1500, 1700, 1400, 2000, 1500 ?
      Is it steady or flactuating ?
    • #14554
      Robert
      At idle Does it stay 1500 rpm ? ==== > or does it do this 1500, 1700, 1400, 2000, 1500 ? Is it steady or flactuating ?
      Quote It jumps gently, 1500, 1700, 200, 1700, 1500 … something like that. But on a cold engine the first 3 starts from 1 work normally, then it starts to jerk when starting, at low revs. Gas to the max and the engine barely moves, suddenly it accelerates rapidly.
    • #14555
      Robert
    • #14556
      Check this link and follow it , then come back to this thread to see if it even helped  or not.
      GV125s idle speed when hot
    • #14622
      Robert
      Today the error disappeared, the engine works normally. I didn’t do anything. We’ll see what the future brings.
