Julian
  • Topics: 4
Hi there laser beam, sorry once again mate for my lack appearances lately. I have been meaning to reply with a picture of my home made dealer tool.
As you can see in the picture, its pretty basic. Its just an on/off toggle switch with some wires, plug and heat shrink. A simple continuity test shows which is on and off on the switch. I wired in a matching plug in place of the factory one to suit the one used on my dealer tool.
When I used it, I plugged it into the wiring harness on my bike with it switched OFF. I turned on the ignition and kill switch so that the fuel pump primed so that the then usual CHE would come up on the dash. I then turned the dealer tool to ON and then the c12 code came up on the dash!
I hope this helps! Cheers.
