‘dealer toolโ to diagnose fault codes. They plug into the port near the fuse boxes in the tail of the bike and theyโre simply an on/off switch. All they do as it turns out, is toggle between one of two modes in the ecu. Normal mode and diagnostic mode. So, I made my own. It triggered a code to display on the dash which was c12. The manual says its the pick up coil fault. The stator and reg/rectifier were near new and clearly not the original factory ones. There was no way that they were connected to the wiring harness. I corrected it by plugging the pick up coil plug into the matching plug on the wiring harness based on the matching wire colours and hey presto, she finally fired up!
That’s awesome. I’m really glad your bike is running. I didn’t want you to spend too much cash.
Please post a picture of the dealer tool you made, to toggle the ECU modes. Gonna add one to my tool kit for my next Hysoung, im already looking at ๐
-----LaserBeam---->
