Hey,
If the master cylinder is lower than the clutch perch sort of like   —___ staggered fashion being shown by your mirrors.
Look on amazon for something like “m10 mirror” extender   (it’s a hollow nut that screws in between the mirror and the master cylinder
You may need to use 1x m10 washer on the clutch side to even things out.
Not something that’s around  “plug & play” style ,   it’s something like a custom job where it involves getting something like “Domino Quck Action” throttle” and you have to fabricate your own custom throttle cable as obviously the oem throttle cable only is made specifically for the OEM throttle tube and clips itself under the kill switch block.
15T front is OK , just less acceleration  but if you do long rides  rather than short city springs, you may get better MPG  –  Sprocket code is  JT 1554
Does this clutch perch suit you , it’s ours and will fit yours no problem ,
https://www.ebay.co.uk/itm/256243615477
Just message us to include the screw below
Clutch Lever Cable Adjuster – Various Hyosung Models
This perch on ebay doesn’t have a clutch switch, you have a model that is pre-efi with the classic twin gauges , so i assume it doesn’t have it ?
I would mention other hyosung sites but they are scam pages , as too many people have complained (the ones with white & blue backgrounds are all Shopify clones of the same person who owns it)
