You could get the GT650 engine (rare in UK as 650’s rarely get split up for parts now , unless you find a US ebay seller to ship it over to you) which has the factory 6 speed gearbox  or  look to ask the US seller to send the 6 speed gearbox
or
You would increase the size of the front sprocket (though it sacrifices acceleration a little bit) , i “assume” you don’t need to ride very “spirited” around all the time  since the further most north UK doesn’t have much motorways (highways that have you sitting at 70mph all day long) , most country roads are good around 60mph anyways
Hyosung did make the SV motor yes but the internals aren’t all that interchangeable as internals got moved around for Suzuki only  (whereas Hyosung for example has oil filter inside the motor than the real SV does)  , looks can be decieving.
Cagiva Mito 650 is all Hyosung in an italian frame but i can’t remember if it’s 6 speed.
