Reply To: Hyosung GT 650 s sætter ud efter høje omdregninger Jun 4, 2024 at 6:30 PM #13647 Cobra2Participant Too high idle-RPM… check first; throttle-wire, condition & adjustment…: does the throttle feel smooth, does the throttle go to its (low)end-point when dropping the handle? Wire adjusted too tight? check for any vacuum-leaks… Jun 4, 2024 at 6:30 PM #13647 Cobra2Participant Too high idle-RPM… check first; throttle-wire, condition & adjustment…: does the throttle feel smooth, does the throttle go to its (low)end-point when dropping the handle? Wire adjusted too tight? check for any vacuum-leaks…
