Jun 3, 2024 at 10:42 PM
#13633
it comes underneath the tank on the right side and doesn’t go anywhere but petrol comes out of it
This picture, are the pipes attached to the fuel pump itself going the right direction ? I could be wrong but it seems like fuel is going to the bottom of the pump
Usually the PUMP itself has arrows for fuel flow direction and it looks kinked on one of the pipes , could explain running issues too.
Maybe rotate the pump again ?
Also i still can’t see which pipe is leaking fuel , maybe lift the tank and hold the pipe while getting a picture?
