Viewing 10 reply threads
    • #13602
      John
      Hi Marcel just to let you know I have got it running apparently it was the floats in the carb weren’t opening thanks for all you help but I have one more problem it’s the pipe on the underneath the tank I have had to plug it  because the petrol come out off it and I can’t find any we’re it goes i sent a photo of it some one said it was a over flow from the tank but it can’t be because the tank is nearly empty  so the overflow is out could you help with this it would be much appreciated
      Thanks again
      John
    • #13607
      Post pictures on your next reply by clicking “ADD MEDIA” green button.
      So we can see and verify which pipe it is.   A few pictures would be best.  (where it starts from and where it ends)
    • #13611
      John
      it comes underneath the tank on the right side and doesn’t go anywhere but petrol comes out of it
    • #13612
      John
      Don't know what the pipe is for
    • #13614
      John
    • #13632
      This picture,  are the pipes attached to the fuel pump itself going the right direction ? I could be wrong but it seems like fuel is going to the bottom of the pump
      Usually the PUMP itself has arrows for fuel flow direction and it looks kinked on one of the pipes , could explain running issues too.
      Maybe rotate the pump again ?
      Also i still can’t see which pipe is leaking fuel , maybe lift the tank and hold the pipe while getting a picture?
    • #13633
    • #13634
      On this SECOND picture, is the pipe dangling down physically attached to the bottom of the fuel tank or is it coming from a carb ?  Try another picture ?
    • #13641
      John
      Yes it is physically attached to the tank from underneath
    • #13649
      John
      As to the running problem I have sorted that out the problem was the floats in the carborator weren’t opening that has been sorted out now it runs fine it’s just the pipe on the right side underneath normally when I have seen that on some bikes it joiner both side of the tank together  but there is nothing to show that on this bike so I am stumped
    • #13651
      It overflows to the road,  and it is also a breather pipe  (vent) , so let guide it on the frame until it faces the road.
