I assume the pump stops if you flick the Stop switch? This would indicate that the switch is ok CHE is the dash not getting a signal from the ecu. This will occur if you flick the stop switch but otherwise it should just show the speed. If the stop switch is ok then check the speed sensor too. Also, I would highly recommend checking over the loom, continuity testing each location. As the loom is used you donβt know its history or if it has any loose connections from being removed.
yes the fuel pump primes for a few seconds then stops on its own with the kill switch turned on. The display shows CHE both when the kill switch is on and off. Fuel pump primes now every time the switch is on.
What key components do I need to be focusing on here now? I can do continuity tests and all that until the cows come home but I need specifics as I believe its ignition related now.
