Chris
  • Topics: 8
I assume the pump stops if you flick the Stop switch?  This would indicate that the switch is ok
CHE is the dash not getting a signal from the ecu.  This will occur if you flick the stop switch but otherwise it should just show the speed.
If the stop switch is ok then check the speed sensor too.
Also, I would highly recommend checking over the loom, continuity testing each location. As the loom is used you don’t know its history or if it has any loose connections from being removed.
