May 30, 2024 at 8:35 PM
#13557
Is the bike running normally now ? and have you been out on it ?
I’d say it’s not a bad call to replace the injectors and re-check the wiring between injectors + pump back to the ECU, but i believe in regards to wiring you have been through it enough times.
