Did you get caught out in heavy rain ?
Lift the tank , and look for the “BLUE SOCKET” thats along the steering VIN number or the opposite side, it might be water logged
Can you open the dash unit safely to see if its water logged inside  (usually they can resist water) unless the seals around the glass gauge allowed water to invade the unit  ,   the  “blinking icons like neutral, signals, high beam, etc” will have their own independent lines in the same harness
The dash unit  “Speedo REVS and  MPH + FUEL GAUGE” use a red wire ,  maybe it broke off when it was kinked up, have a look at that too ?  That’s its “main power” feed line to turn it on, it is on the same red wire going all the way to the aformention 9pin blue socket plug under the tank.
Let us know!
