Steve
My ST7 takes about that to lose the first two segments, especially if I’ve been careful to fill the tank to brimming.
Certainly the last two segments disappear rather quicker which is fine once you’ve got a grip on approx how much fuel you’ve got left. The gauge is sometimes rather slow to react however and can be affected at lower fuel levels by gradient, acceleration and braking.
I’m not sure if it’s similar across the range but the ST7 has the last segment go into flashing mode when your’ve really low, I reckon I’ve got about 10 miles (at 45mph, top gear) left then so enter personal panic mode here in the Welsh wilds.
Regards, Steve.
