May 21, 2024 at 7:10 AM
#13442
I’ve just put another harness and ecu on mine (early EFI) … I would recommend checking the colours etc against the loom you take out before powering up. Also power up without the ECU on, as there’s plenty you can check without it on, save blowing it! I’ll be uploading some wiring tips in the near future.
Good stuff, Chris thanks mate. Don’t stress if it’s too hard bro. I don’t wanna put anyone out.
I hope Julians ECU is ok, as they are expensive. A entire used wiring loom is about 89Pounds Sterling or AU$170.
The ECU’s cost a lot more.
-----LaserBeam---->
