May 20, 2024 at 12:59 PM
#13430
I’ve just put another harness and ecu on mine (early EFI) , one thing I found was that the wiring to the dash, headlamp, speed sensor and indicators was slightly different on the new loom but not sure if either my original one or the new one had been messed with.
I had to take the pins out of the block connector and reorder. I would recommend checking the colours etc against the loom you take out before powering up.
Also power up without the ECU on as there’s plenty you can check without it on, save blowing it!
At the request of Laserbeam I’ll be uploading some wiring tips in the near future (once I’ve validated it).
I swear the factory just used what they had to hand and didn’t to a controlled year change for parts.
