Hi guys, thanks again for your input. Just to elaborate a little on the bikes current status. So, the bike isn’t any different in the end other than having a dash that powers up with funny display readings!
With the ignition key turned on and kill switch turned on, the headlight comes on as before. High and low beam work fine and indicators work fine. The dash now comes on but no fuel pump as before and no CHE on dash. Dash just shows as pictured in previous post both with ecu unplugged and plugged in! Pull clutch in, hit starter and motor cranks as before. Ive done all this over and over again with the bike on a paddock stand, with the side stand down, up and switch bypassed. ive also tried all this both with factory relays plugged in and with all new ones plugged in. NOTHING HAS CHANGED!!!
I’m really suspicious of the ecu. Not having any luck finding a 2nd handΒ s&t/daewoo ecu like the current one and I’ll be f$Β£#@d if im spending 1200 bucks on a new one! so I’m taking a gamble and ive bought a delphi ecu and complete wiring harness from a wrecker. Both are from the same bike, a 2012 gt650 naked. The same bike that the dash came from as a matter of fact.
Ive decided to do this as every google/ebay/gumtree search ive made looking for parts seems to come up with 2nd hand delphi ecu’s predominantly and haven’t once come across a s&t/daewoo ecu other than brand new ones and others suitable only for gt250, gt250r and gv250’s.
Ive also dropped my original, unresponsive dash into a place called ‘guage works’ to get fixed. They specialise in automotive and motorcycle dashboard repairs so hopefully they can work their magic and I can have a dash that finally works properly and doesn’t read 729429kms!
I’ll keep you guys posted. Thanks again for taking your time to give me some insight and advice.
