LaserBeam
  • Topics: 14
Ive since got the other dash, it powers up finally. Zeros show on LCD screen as sevens!  original dash was broken somewhat. Still no fuel pump priming up and no start. There’s no CHE or anything on the dash. Interestingly even with ecu un plugged, it doesn’t change the display. Im thinking that the ecu is screwed?im really beginning to loose faith in this thing.
G’day Julian, hang in there mate. Glad the dash lights up but odd speedo readings; no way the bike has done 729,000km. Swapping or returning the 2ndHand Speedo as Marcel said is a good option if it’s there. Marcel’s idea of a new starter motor SOLENOID is a good one. Often overlooked – won’t let your bike turn over. They affordable & comprise of a positive screw, a negative screw and a connector. Easy.
I don’t like the fuel pump not getting power thing. idk but maybe the ECU has taken a blow. At least you know there’s a wiring or electrical issue now. There’s a guy in SA selling a wiring harness for a 2010 or 2011 model efi GT650R on eBay. He may have the ECU too. Ask the sellers that have your EFI model. Check your SERIAL NUMBERS and year & match the serial. When it’s running you’ll be smiling big time & forget about the work that went in.
-----LaserBeam---->
