I would say the pump is toast if a direct 12v feed isn’t priming it up  ,  or have you taken it out of the tank and confirm the strainer isn’t clogged or a wire hasnt broken off inside the pump itself. ?  Usually a yellow wire inside the pump is a culprit.  be wise though,  fuel is explosive! 💀  Take it easy.
