A 2010 Naked 650 will have the same electric dash (one with LCD glass) , and it will fit your 2010 GT650R
Your readings for the orange and red wire is good! – So it looks like it might be dash being faulty , and did you smell inside the dash for any burn marks or signs of water invasion to it ?
I pray it wasn’t fried due to bad battery and regulator (hence 99% of Hyosung 650 owners replace them with proper Shindgen Regulators like you see on this shop)
Stators = I hope the current one is OK , if not, it will stop any sparks. And if it does work, each single yellow wire must output 80v @5k revs , identically all 3 , as it’s a 3-Phase unit. When it is ice cold overnight , each single yellow wire must be under a single Ohm (Ideally 0.3 – 0.8 ohm max) , if it’s beyond 1.00 ohm , replace it right away.
The pulse trigger (2 pin stator plug) = Should be under 140 ohms ice cold overnight
