May 4, 2024 at 9:31 PM
#13284
DO you have standard indicators or LED ones changed up? DIsconnect the indicators by their plugs (incase there is a kink or damage along the harness) Or the relay has gone burst. (We don’t know if you use OEM relay or LED indicator Relay) Also, it would help to strip the bike down to follow all the wires for the indicators because we don’t know if the rain water has caused electric issues or if there is a wire in the bike that is rubbing against the frame (causing a short , then the bike switches off)
Stripped back the wirering loom, found broken wire and lot of moisture,so hopefully will solve issue
