Viewing 3 reply threads
    • #13183
      Will
      Hi guys , when I put indicator on my hyosung gv 125sĀ  it cuts out, would it be a bad earth somewhere, thanks.
    • #13195
      ā™ ļø M77
      DO you have standard indicators orĀ  LED ones changed up?
      DIsconnect the indicators by their plugsĀ  Ā (incase there is a kink or damage along the harness)
      Or the relay has gone burst.Ā  (We don’t know if you use OEM relay or LED indicator Relay)
      Also, it would help to strip the bike down to follow all the wires for the indicators because we don’t know if the rain water has caused electric issues or if there is a wire in the bike that is rubbing against the frameĀ  (causing a short , then the bike switches off)
    • #13284
      Will
      DO you have standard indicators or LED ones changed up? DIsconnect the indicators by their plugs (incase there is a kink or damage along the harness) Or the relay has gone burst. (We don’t know if you use OEM relay or LED indicator Relay) Also, it would help to strip the bike down to follow all the wires for the indicators because we don’t know if the rain water has caused electric issues or if there is a wire in the bike that is rubbing against the frame (causing a short , then the bike switches off)
      Stripped back the wirering loom, found broken wire and lot of moisture,so hopefully will solve issue
    • #13287
      ā™ ļø M77
      Fingers crossed you will resolve it!
      This topic is locked as you made a duplicate one, so i will keep an eye on the video that has a video uploaded inside.
  • The topic ‘Bike cuts out – GV125S (Duplicate topic/Locked)’ is closed to new replies.
