Chris
  • Topics: 8
I’ll keep posting.  I just hope that there is no damage due to the previous attempts to fix it.
The original issue was it stopped running,  according to the garage report they looked at it and found the side stand wires had been cut and 4 wires (I found more) wrapped together.  The reports says suspected ECU fault.   I wonder if joining all the G/R wires (that’s sensors and side stand and starter relay) together had fried the ECU as on the diagram they are separated.
That was back in 2018!  The guy I bought it off said they had had it running but only on 1 cylinder,  and then someone else tried to fix the wiring.  Not sure at what point the ECU was cut out.
I’ll just have to keep an eye on and spread the cost otherwise I’ll be nick naming her the Money Pit 😆
