- This topic has 15 replies, 2 voices, and was last updated 2 years, 6 months ago by
Chris.
Apr 26, 2024 at 10:26 PM #13148
ChrisParticipantHi, I have bought a 2009 GT650R. Someone’s been messing with the wiring loom and it’s currently been fitted with a DL650 ECU and also came with an SV650 ECU. Both Mitsubishi with 2 plugs.
Not everything had been connected, bike doesn’t run and so be on the safe side I’ve striped the loom of the bike to repair the damage and make sure everything is wired correctly.
How do I find out the correct ECU for the bike? And also which manuals are the correct ones. The bike was registered late 2009, yoke has Comet GT650R on it, so I assumed its the FI?
Any help is appreciated.
Thanks Chris
Apr 27, 2024 at 5:22 PM #13153
♠️ M77KeymasterIs it possible to:
- Show us the plugs of the ECU
- has it actually got an EFi system (injectors on the engine) or Carbs ? (Originally before the owners started messing around with it)
- On the harness (i hope) there should be a part number sticker printed along it (eg. 1245XYZ-HG-1234 GT650S)
Pics of the ECU’s you have currently attached to that harness. (As it will have part numbers printed to it)
Apr 27, 2024 at 7:16 PM #13162
ChrisParticipantSo managed to work a few more bits out. It’s defo an Injection model. There’s no label/code on the loom, but its the correct one for the bike, everything plugs in OK (except ECU issue).
The original ECU is missing, I have a receipt for garage work a previous owner paid for, it was having engine trouble and the garage had reported it was the ECU. So it’s been tackled by a bodger and rather than using a GT650R or other hyosung ECU its had the original cut off (YES CUT OFF!) and then the ECU, connectors and short bit of wire grafted on from a Suzuki DL650., however most of the wires weren’t connected and I think some were wrong anyway.
The DL650 ECU is a F8T51171.
I have pinned the loom to a board, and using the wiring diagram from the Comet GT650R manual (earlier one), I have mapped out all the connections. I have identified all the cut wires at the ECU end and put them in order into choco blocks (just to hold them) and then continuity tested to make sure they are all OK from the plug to the cut end (ECU)
So I’ll need an ECU, the connectors and a bit of the loom to regraft it on, or new connectors with the pins.
I was thinking about what if I get a slightly later Delphi unit and graft that on, obviously I can ensure the correct wires goto the correct pins due to them all being cut!!
Only thing I need to investigate is the side stand sensor has been removed along with its wiring. I think rather then just bridge the two wires (Green with Red Tracer and Black with White Tracer) they have soldered the Green with Red wire to the other Green with Red Tracer wires.
Apr 28, 2024 at 5:38 PM #13179
♠️ M77KeymasterA Delphi ECU would require an Delphi Harness and possible some sensors and even coils changing over to DELPHI
Please call Startright Motorcycles tomorrow and tell them we sent you as i know 10000% they have an ECU on their shelf , last time i went to see them but i can’t remember which one it was
I hope it’s the black one or at least they will even have an old 650 harness laying around.
I don’t like what the previous keepers did , it makes it hard for you or us as sellers to get you correct parts afterwards,
They would have at least drop the actual SV650 lump in their with all its ancillaries in to the frame otherwise , Hyosung likes everything to be Hyosung or nothing works as you found out clearly.
Apr 28, 2024 at 10:07 PM #13182
ChrisParticipantThanks, I’ll have a chat to them to see what they have.
I’ve “re-done” the bodge that someone had attempted previously, using what I think is the correct service manual for the SV650 ECU I have, and “mapped” the pins to the correct location (sensors, coils etc).
So, it powers up (which is a start), cHE on dash as expected. Putting a wire across the dealer 2 pin doesn’t do anything (might have it wired wrong, assume its Black and Black with White Tracer, but not 100% where on the ECU I have). Engine turns on the button but no spark. But nothing blew up so I’m happy!! Lights work, inc neutral, etc on dash.
During the rewire I found the Loom code. not very clear but I think its 36610HR9701 GT-650R,
Apr 29, 2024 at 7:04 PM #13196
♠️ M77KeymasterBased on that part number, the harness needs an ECU that was made with Mikuni & Mitsubishi specifically for the Hyosung 2008 bike (The harness you have is a 2008)
That means you should have a “black dashboard with GREEN TEXT” on it too. So i don’t think Suzuki ECU’s will run well. The dashboard & stators in the bike respond to a Hyosung ECU also and even as much as getting an error code on the dash will need a Hyosung ECU
Hyosung moved on to DELPI these days , so to actually replace the ECU is rare but it is possible i could get one , if Startrights doesn’t come through , but its stupid expensive (almost £1k to get one & it will take time due to special order status)
Apr 29, 2024 at 9:56 PM #13209
ChrisParticipantThanks for the info…
“black dash with Green text”?? I’ve attached an image of the dash and also the bike (prior to me striping it).
If I look at the wiring diagrams in the 2 service manuals (EFI and FI) the blue connector going to the dash matches that of the EFI manual (in that it has the same colours and is 9 pin, whereas the FI shows different colours and 8 pins).
Might have to play the waiting game for more to get broken down or find another spares and repair to pull the bits from. I can wait it out, as I have other work to do on the bike all of which is little or no cost, just time.
Apr 30, 2024 at 10:20 PM #13226
♠️ M77KeymasterDid Startrights come through with the ECU ?
Apr 30, 2024 at 10:42 PM #13232
ChrisParticipantI had to drop them an email whilst in work, not had a reply yet.
May 1, 2024 at 8:13 PM #13240
♠️ M77KeymasterI had to drop them an email whilst in work, not had a reply yet.
Best to ring them , usually are faster on that one 🙂
May 1, 2024 at 9:15 PM #13248
ChrisParticipantCheers will do.
I’ve been checking all the loom and found the way the kick stand had been cut out didn’t look right so redid it. Anyway, all the sensors are getting power and seem ok with the exception that the TO sensor is showing around 5V which looks high compared to the manuals, however the fuel pump runs. Engine turns on the button.
Even if there was a chance the Suzuki ecus could work, they might be knackered as there was quite a bit wired up wrong and it wouldn’t have worked for the previous person anyway as the Suzuki Ecus require a power signal with a 100ohm resistance (which I’ve sorted) to stop hot wiring.
As it currently stands, no spark, cHe on dash (but no FI light), dealer mode doesn’t work.
First EFO bike I’ve had to play with so enjoying learning how to check it all.
Bit of a bonus…. Due to a previous job I have found access to the ECU connectors, even the Delphi ones, so as long as I can get an ecu (pref one from around 2008/2009, and the pins match one of the manuals, I’ll should be able to repair the loom to get it running.
May 2, 2024 at 8:11 PM #13265
♠️ M77KeymasterIf you can’t find an ECU, ill order one for you via trade but you can also message “SunCoastCycleSports” as they have been wonderful Americans getting us rare 650 parts over to my workshop to fix customer bikes SCCS have a public website, i am sure they are a US dealer. But see what Startrights says, i won’t like a lot of people give up even thinking to mess withthe harness, so i will be watching this thread for sure 😉
As long as the sensors work, that’s good but yes the dash has a microchip that expects a Hyosung ECU to run it correctly.
May 2, 2024 at 8:46 PM #13268
ChrisParticipantI’ll keep posting. I just hope that there is no damage due to the previous attempts to fix it.
The original issue was it stopped running, according to the garage report they looked at it and found the side stand wires had been cut and 4 wires (I found more) wrapped together. The reports says suspected ECU fault. I wonder if joining all the G/R wires (that’s sensors and side stand and starter relay) together had fried the ECU as on the diagram they are separated.
That was back in 2018! The guy I bought it off said they had had it running but only on 1 cylinder, and then someone else tried to fix the wiring. Not sure at what point the ECU was cut out.
I’ll just have to keep an eye on and spread the cost otherwise I’ll be nick naming her the Money Pit 😆
May 10, 2024 at 8:29 PM #13347
ChrisParticipantIf you can’t find an ECU, ill order one for you via trade but you can also message “SunCoastCycleSports” as they have been wonderful Americans getting us rare 650 parts over to my workshop to fix customer bikes SCCS have a public website, i am sure they are a US dealer. But see what Startrights says, i won’t like a lot of people give up even thinking to mess withthe harness, so i will be watching this thread for sure 😉 As long as the sensors work, that’s good but yes the dash has a microchip that expects a Hyosung ECU to run it correctly.
spoken to Startright. They’re going to get back to me. In the meantime I’m going over the bike with a fine tooth comb….
May 11, 2024 at 12:02 PM #13352
♠️ M77KeymasterGood to hear. Follow up incase they forget they can be busy at times! Ring the phone off the hook 😉
Fingers crossed.
May 19, 2024 at 1:52 PM #13420
ChrisParticipantI now have a spark!! Got an ECU and Loom from a 2008 EFI model.
Now I have a fuel pump issue (see new post!)
