Based on that part number, the harness needs an ECU that was made with Mikuni & Mitsubishi specifically for the Hyosung 2008 bike  (The harness you have is a 2008)
That means you should have a “black dashboard with GREEN TEXT” on it too.   So i don’t think Suzuki ECU’s will run well.   The dashboard & stators in the bike respond to a Hyosung ECU also and even as much as getting an error code on the dash will need a Hyosung ECU
Hyosung moved on to DELPI these days , so to actually replace the ECU is rare but it is possible i could get one , if  Startrights doesn’t come through , but its stupid expensive   (almost £1k to get one & it will take time due to special order status)
