Chris
Thanks again guys for your input. Im trying to track down some spares like another dash and maybe an s&t ecu like what’s in my bike but not too many wreckers around in Adelaide other than MR motorcycle wreckers. I plan on carefully removing the entire main harness and thoroughly checking for breaks and testing on the weekend. Can’t resume work until then as I work/stay in Adelaide during the week and only home on the weekends and live over an hour away! Its blatantly clear that this old girl has been screwed with by ham fisted previous owners but I’ll endeavour to solve what’s wrong. These bikes are pretty much a knock off sv650 and can’t be a bad thing! I’ll keep you posted 👍
Taking the harness out is quite easy with the exception of a couple of connections that are a pain as they are under the rear throttle body.
I’m currently working on a GT650R  non runner due to someone chopping out the ECU and did the same to check the rest of the loom.
The wiring diagrams in the manuals are helpful for this,  just pick the right one based upon the number of pins on the blue dash connector (8 or 9).
I pinned mine to a board and marked it out (the bundle of wire where the ECU should be is the mess I was given to sort!)
