LaserBeam
πŸ‘€ Member
  • Topics: 14
[youtube https://www.youtube.com/watch?v=VtmQlokrTWs?version=3&rel=1&showsearch=0&showinfo=1&iv_load_policy=1&fs=1&hl=en-GB&autohide=2&wmode=transparent%5D So ive made and uploaded a quick video to YouTube as requested. I haven’t had any time to play around with the bike since the last time as ive been flat out with other things. Looking forward to hearing any further advice! πŸ‘Quote
G’day mate. You’ve done well uploading a video – i don’t know how to add a photo.
Im guessing it’s an electrical issue like a short or broken/disconnected wiring.
There’s a translation of the Hyosung Wiring Diagram online that explains their diagram a lot better.
I bookmarked it i think. Auto Electricians are expensive but are a good option if all else fails.
I’d buy a 2nd hand Speedometer, just to test it.
You can buy a 2nd hand one for around AU$100-150. A new one costs about AU$500-600,
My guess is that your speedo is ok though.
As some things like starter motor and lights work but your fuel pump doesn’t it sounds like you have an incomplete circuit.
Marcel and the guys here should be able to help you with testing the wiring.
I’d buy a 2nd hand ECU before a new one for test purposes after electrical checks.
idk about these ECU’s but normally sensors fail well before an ECU but its possible.
Stick with it; the twins are a good fun machine.
I’ve never owned a bike with hazard lights before. Did you wire them like that or is that the switch?
-----LaserBeam---->
