Hi guys, new to the forum and seeking help. Ive picked up a 2010 gt650r efi for cheap recently as a project bike. Bike was completely dead when I got it and had a broken headlight. Ive replaced the battery and headlight which obviously needed to be done. So, with the ignition and kill switch turned on the headlight comes on but not the dash. Low and high beam works, brake light works and so do the turn signals. No sound of fuel pump priming or anything. When i Pull the clutch in and hit the starter, the motor cranks but won’t start. I found a blown fuse in one of the 2 little fuse boxes at the back left of the bike but didn’t seem to solve anything. What’s wierd is that the neutral light, turn signal lights and high beam lights work on the dash but nothing on the lcd screen or tach and no background illumination. In the attached picture it shows the 2 blue relays, 2 black fuse boxes, 1 brown thing with a removable black cap ( i think its a resistor or something?) And 2 white plugs with nothing connected to them. Is there something missing? Any advice would be greatly appreciated. Thank you
hi pal, them plugs look like they need to be connected to a cdi unit, ive just had to do the same on my 2008 gt650r, ive got a brand new cdi unit which i bought wrong that looks like it fits your 2 plug cables
im not 100% but it might be worth looking into if it can help
Those plugs hanging from his bike would be for relays unfortunately, your ECU says “GV650” , he has a GT650R
