Apr 15, 2024 at 4:11 PM
#12963
This is the set I got from AliExpress, changed them recently. Also to mention again bike used to run fine, until I messed with this cable that is on right side of bike (
Then it means you will need to re-adjust that screw again.
“clockwise” = more revs
“anti-clockwise” = reduce revs
If its too low, it won’t start,
Try to turn it to maximum clockwise , then start the bike, and quickly reduce it until it is around 1300 rpm
When the bike is hot , make sure it is idling at 1500 rpm , then no need to touch it ever again, next time it will always start and idle at 1500 rpm.
