Looks like you got a weird lockset , generally orange and red at the harness side is going torwards the ignition barrel,  some cases there is indeed a black wire with a white strip  (ground or negative) , and extra red wire if the harness needs it.
Can you call “Startright Motorcycles” tomorrow, they have a dashboard in stock and even the LCD glass , i hope it’s not sold by them – Tell them Marcel sent you.  And clearly specifiy it is for a 2007 era bike that uses a “Matrix Black Glass” LCD with green text.
Your spare harness was sent off today via Yodel, so check your email as P2G will email you themselves for a tracker code to follow it.    Maybe you can save both harnesses and 1 is working , done up well and the other is also a fixed up working backup.
Mannol Harness Tape is ace for wrapping harnesses  (we use it all the time)
