Hey welcome and Happy Easter!
Hmmm, i read all you have said,  how about   look for the noise source  (make sure your ears are closest to the source of ticking or using the ear and screwdriver trick, that will highlight the closest area of the noise.
Also consider these ?
  • Crank Shaft Bearing
  • Starter Motor Sprag clutch  (behind the flywheel there will be 3x balls)
  • Flywheel Sprocket Needle Bearings (as thet do spin on the shaft continously)
  • Any play on the Piston Rod   (hints by the piston itself showing skirting marks ?)
  • Piston ROD bearing (on the crank shaft)?
Just throwing that out there and keep us posted!
