Big red
  • Topics: 2
I have ordered new washers and the spacer that goes onto the outer clutch hub, waiting for it to arrive.
When it does all pull the whole lot out and check to make sure everything is within spec, i am hoping its an easy fix 🙂
Funny you talk about the plates, seeing its only got 600km on the clock i assume it would be fine, but ill make sure to check them also.
