Viewing 7 reply threads
    • #12345
      Big red
      G’day gang,
      First time poster, long time stalker.
      Got a strange noise on my gv650 classic.
      History on the bike, first owner purchased brand new then failed his learners twice and then put it in the shed with 650km on the clock.
      Ten years later I purchased it from him, had Ti change the fuel pump and all filters and oils to get running again.
      I have taken it out a couple of times with no problems at all but have noticed that noise in the video.. anyone have any ideas? Have ordered new thrush bearing and washer.
    • #12347
      Simon
      Almost certainly thrust bearing or could be a bust spring
      • #12578
        Big red
        Just finished changing out the thrust bearing. Can confirm it’s still making the noise.
        its a real head scratcher
    • #12417
      Big red
      Thanks Simon,
      Weird how the noise is on the other side of the motor but i have seen stranger things.
      Waiting for the bearing to arrive, fingers crossed its the problem.
    • #12581
      Have you thought about taking out the entire clutch assembly out  (plates and discs) to check for cracks ,  distortions/warping , heat glazed springs that have weakened  (eg.   OEM says example 50mm free standing spring, the old spring now says 30mm free standing, so it is something to think about ?
      Also take out the “push rod” that’s in the middle of the clutch basket  (it just slides out) and check its not bent or warped ?
      • #12772
        Big red
        I have ordered new washers and the spacer that goes onto the outer clutch hub, waiting for it to arrive.
        When it does all pull the whole lot out and check to make sure everything is within spec, i am hoping its an easy fix 🙂
        Funny you talk about the plates, seeing its only got 600km on the clock i assume it would be fine, but ill make sure to check them also.
    • #12793
      Charger1284
      Hi Also You can check the axial  bearing ( sorry if it is called diferrent in English ) that spin agains the presure plate  when You press the clutch since the noise stop once it have presure and Start when it is free
      • #12815
        Big red
        Hello,
        Yep already changed that, but noticed once i put it all back together you could adjust it, but cant find anything on the internet or in the manual about it.
        Waiting for parts to come this week so i can pull it all apart and check everything this weekend 🙂
    • #12816
      Charger1284
      Hello, Yep already changed that, but noticed once i put it all back together you could adjust it, but cant find anything on the internet or in the manual about it. Waiting for parts to come this week so i can pull it all apart and check everything this weekend 🙂
      Hi hopefully it helps the Suzuki GN uses the same system, I will try to find simething in English
      • #12818
        Big red
        Perfect Video ! exactly what i was looking for, time to learn and new language 😆
    • #12817
      Charger1284
      If You see the components are almost the sames as Hyousung Even I used this procederé to ajust my clutch
    • #12820
      Charger1284
      I this but it is in Indian or other language maybe the subtitles can Help
