The brake light is still working. Do you reckon I should check the wires and fuses first?
If you see red lights = the unit is working ,    it could be your RELAY because newer generation Hyosungs uses RELAYS to control the front and rear lights
(Click this link to see it)
You will find this relay located on the LEFT REAR COVER of the pillion seat.
Maybe clean the contacts and check wires ?  If nothing,  it could be the relay or there is a “break” in the wire along somewhere at the back that is stopping the voltage signal going to the Red LED’s at the back.
The “Brakes” will trigger the LED,  independently.   The brakes use their own switch attached to the master cylinders.
