Mar 19, 2024 at 9:04 PM
#12656
I can see the wire to the tail bulb but cant get it out, seems like it’s jammed inside. Do I just pull harder? Cheers
Is it a “single bulb” or do you have LED OEM Rear light ?
(Korea changed lights in 2009-2012 onwards for GT bikes to have factory red LED’s at the back.
If it is a bulb type (older shape model Hyosung) = You can try what Simon said! (use a little bit of contact cleaner around the bulb and socket to free it off a little bit and be gentle.
