Mar 15, 2024 at 8:29 PM
#12611
From the handle bars (left for choke) and (right for throttle) – Remove the cables from the handle bars Then you can remove your carbs with the cables still attached to their carb. Now you can see what’s causing them to seize on the table somewhere. This will protect your “rubber intake” pipes close to engine heads from splitting or getting stress under pressure
Thanks for the guide, I managed to clean up my carb by disconnecting it as you said.
Now bike will start (no need for choke to start it up)
It idles at 2.5k rpm (without choke, is it okay?)
Digital dashboard won’t turn on or show anything and front lights aren’t turning on or working either.
My question is what can I do about it?
Check front wiring? relays?
