Have you thought about taking out the entire clutch assembly out  (plates and discs) to check for cracks ,  distortions/warping , heat glazed springs that have weakened  (eg.   OEM says example 50mm free standing spring, the old spring now says 30mm free standing, so it is something to think about ?
Also take out the “push rod” that’s in the middle of the clutch basket  (it just slides out) and check its not bent or warped ?
