Martin Sorensen
  • Topics: 3
I can make that video in the morning, Any special thing we are listening for ?? The bike makes all the normal sounds (fuelpump and idle valve) and then is ready to turn over, but just no start, well starter turns over, just no ignition. Will check spark tomorrow.
At the moment, the gas tank is off, cause i was trying to find this sound that the idle speed control valve is making, but the sound is the same with the one i bought from you.
These are the parts i used when stator blew up, thought that china parts for a china bike would be fine, and they tests out fine when messured at !!
Stator that i put in.
https://www.aliexpress.com/item/1005005887007181.html?spm=a2g0o.order_list.order_list_main.34.3c451802P0YJw7
And the regulator i used.
https://www.aliexpress.com/item/1005003874923640.html?spm=a2g0o.order_list.order_list_main.38.3c451802P0YJw7
