Reply To: HELP! Power problem! Hyosung Aquila 125s Dec 30, 2023 at 11:16 PM #12070 JoelParticipant Try running it with a full battery and see if the battery runs flat, if so you could have a Regulator/Rectifier (indicated by the bad lights) or more likely Stator issue. Hope it helps!!
