Viewing 3 reply threads
    • #12062
      Kenan
      Does anybody have a service manual book for the Hyosung Aquila bobber 125s? If so that would be brilliant please send it to me!
      Or a picture of where the relays go under the seat? Or any information on how I can fix my bike?
      This all began when I had a problem with the starter button, i opened up the button cleaned the connections. Didn’t fix it. I checked the wires connecting to the button and soldered them properly. Didn’t change anything. I then took out the spare fuse in the fuse box and it fixed it for about ten minutes. It then went back to not working.
      I Then took the relays out and put them back (but not in the original places I think) and now the electrics aren’t working properly they’re flickering on and off. Does anybody know how I’ve messed this all up?
    • #12065
      Simon
      It might seem a stupid question but is the battery fully charged
    • #12070
      Joel
      Try running it with a full battery and see if the battery runs flat, if so you could have a Regulator/Rectifier (indicated by the bad lights) or more likely Stator issue.
      Hope it helps!!
    • #12619
      Luka
      Hello I have had same issue and I lost the ground to starter relay (signal wire). I have used new wire directly from battery ground and it solved the problem.
