Dec 14, 2023 at 7:48 PM
#11943
So if you followed the manual exactly (this is after unplugging the ECU for a day & removing the battery for a day) , then you reconnect it all back , do the the paper clip trick, the ECU doesn’t even throw a code ?
And yes a compression test is a very idea at this stage so we can rule out that both cylinders compress enough to start the bike.
