Dec 11, 2023 at 10:35 AM
#11908
Hey,
Can you open the bike on full throttle ? or was it ever dyno’d ? – I would say since it’s a carb model, it would be similar to the efi where the there would be either:
- Restrictor Plate that limits the air flow in the intake throats (least i expect that for some EU models)
- Restrictor Plate for the throttle that stops the carbs going full throttle (can only go up to certain revs, etc)
Any other restrictions will be across all GT models (LAMS or not) usually is the exhaust muffler & intake air filter , plus if its carb the jets will be downjetted slightly (least here in EU for silly emissions control) but it would still be a full throttle bike even with these applied
In AU , its commonly the throttle restrictor plate being added to stop the bike going full throttle either carb or Fi. Just EFi is more common now.
