Have you managed to get the service manual from my previous comments and trick the ECU to spew out an error code ?
So that we have a better idea what sensor is acting up , that prevents you from starting it (I mean if it screams to life, then dies , then the ECU has probably cut the sparks off if one of the sensors on the bike is acting up) or see below about compression
Bike will ride without a speed sensor that is on the left bottom fork leg (your cut 3x wires you see down there) , the dash will just say 0 mph / 0 kmh
Also find out if you can do a cold compression test and let us know the figures?
- All spark plugs out
- use the metal pipe with a curve rubber tip of the compression tool
- Hold it down hard, crank the bike for 5 seconds max
- Read the compression for front engine
- Repeat above ^ for rear engine
- Do this with full throttle open too.
Process of elimination now! (Well, until we get to the part that was stopping the bike starting or engine has something out of spec such as compression)
Regards
