Nov 26, 2023 at 8:41 AM
#11761
Check the battery voltage & charging system first, if the charging has gone down & the voltage drops as it will all sorts of things start happening so check that first.
I forgot to add to main thread I had check all wiring and charged the battery but thank you for your reply, hopefully after I get a replacement injector my problems will be solved
