Dave
Was the ECU Delphi? And all electronics have delphi branding on it Or if you want post a picture of the ECU , stator of the wrecked engine and its flywheel. It could likely be the stator unit compatibility with ECU due to fact certain stators want certain ECUs. The stator and ECU are the 2 to talk to each other while cranking to make pulse timings Then ECU primes the fuel pump and wakes up all other electrics to make flames (sparks) to get her going The carby vs efi engine = purely the actually sensors on the motor to switch. (ET sensor , if its there on the head. Some dont have it. Stator unit, NEUTRAL sensor (efi tends to have 6 dots on it. Carby gearbox sensors tend to have 1 dot or 5) Regards
Hi Marcel,
Thanks for your reply. All the sensors are the ones from the original engine.
Yes the ECU is a delphi and i didn’t swap the stator.
As you’ve said these are all.matched units so that’s my next mission. Change the stators over.
So all the sensors, efi etc are from the original efi bike/engine.
It will take a couple of days till i can do this so will post an update then.
Thanks so much.
