Oct 17, 2023 at 6:43 AM
#11395
The problem is going to be ECU, you need a carb one, the wiring loom is going to be completely different yes the indicators, lights etc are going to be pretty much the same but it’s all the rest of it that’s going to be a problem. I’m pretty sure the carb one doesn’t run an electric fuel pump & it won’t work because the ECU won’t fire it up because there’s no signal from all the sensors during load up. Personally I would try to fit the efi stuff to the engine which I would assume can be done (without a real life look I don’t know) Marcel will probably have a better understanding.
