Oct 6, 2023 at 2:07 PM
#11314
struggling to add pictures other than these 3, the blue connector block is showing corrosion inside and out, as you can see there is a green wire that has been clipped off, not sure as to where it connects, also shown are some other generally poor connectors. Other than the shown damage everything else looks pretty normal and as it should, no damaged wire or anything other than stated and shown
