Viewing 7 reply threads
    • #11303
      Tom smart
       Here I have attached images of my loom. It’s for a 2016 hyosung gt125 rc, I lost all electrics on last ride and also felt like I was running on one cylinder, bike has aftermarket ignition switch and headlights. Just trying to get bike rideable again any support is massively appreciated 🙏
    • #11306
      How much time do you have? Looks like first things first is strip the tape away from all the looms to look for signs of burnt wires inside the tape jackets
      Then go on Amazon, get this:
      “MANNOL HARNESS TAPE”  about 6 rolls.
      Let’s start with front to back.  We’re strictly going to focus on rebuild this loom here called “Dash Mini Bridge”
      Strip it down carefully out of its black jacket (sometimes called back harness tape) , so you can look for breaks, sometimes it is the red wire that breaks inside.
      Go back on Amazon and get this:
      “9 Pin 2.8mm” connector with pins like this one below:
      The dash side is called “FEMALE” end   (the blue connector in your pic i’ve mentioned above ^ )
      Keep the male version for the main bike harness.
      =========== NOTE! ===== If the big connectors are not broken, then skip the above connector i asked you to order.
      Next , I can see that the speed sensor plug is missing  (GREEN, ORANGE, Black(?) , that i can see hiding behind the blue plug)
      Get 2.8mm 3 PIN connector  both male and female
      you want to make sure the “FORK LEFT SENSOR” on your front wheel has the same wire colours as the dash board wire, if unsure , keep posting images.
      We got this , just follow as I say , you will get some life out of the bike  (we hope!) , as I will have to try my best to explain everything remotely over here without me having the actual harness myself to repair it.
      • #11318
        Tom smart
        I bought the bike with aftermarket lights, will attach images, it is a whole lot of bodged wiring by the looks of it, bike also has aftermarket plastics or as stated by seller “race plastics”, however I do like the thought of having my lights showing through the eyes of the bike so to speak through the vents
    • #11314
      Tom smart
      struggling to add pictures other than these 3, the blue connector block is showing corrosion inside and out, as you can see there is a green wire that has been clipped off, not sure as to where it connects, also shown are some other generally poor connectors. Other than the shown damage everything else looks pretty normal and as it should, no damaged wire or anything other than stated and shown
    • #11320
      Hmmm, give me till next week to find these 2 pieces for you and advise properly:
      • Headlight “mini bridge” harness , as yours has been clipped all over.   (You might need to buy connectors from us or the actual bridge but i will see what i dig up)
      • “Dashboard Mini” bridge harness , as i will take a picture myself to show our “blue” plug so you can compare.
      I think at this rate you might have to consider keeping the bike electric wiring as “standard” as possible to get it running and the extra gadgets like lights may fry it  (extra WATTS the stator  & bike harness can’t cope with just yet) as the main headlight box on the bike actually takes 55 watts on its own.
      Is the bike full fairing or has it turned to a streetfighter as i can see an aftermarket headlight meant for naked bikes too , besides the spot lights hanging on the cage
      • #11324
        Tom smart
        These are a couple of the pictures from the add, I will have to go on my other phone to find some better photos, but it looks like it’s been bodged to make the plastics fit, my plan is to return the bike to as standard as possible and then work from there, and if I’m doing it which I am then I want to do it properly, I’ll put the time and effort in to get this bike back to where it should be ready for the spring is the goal 🤞🏼
      • #11327
        Tom smart
        The second picture here shows the aftermarket headlights that were active before I lost all electrics, the two spotlights weren’t connected to anything and previous owner said he switched out to the other one as spots were drawing too much power from the battery 🤷🏼‍♂️
    • #11328
      I am not going to lie , I like the look!  – But i also like the original 2016 look for the bike lol.
      So time to do a full reset on the electrics then ?  I got the plugs and –  I do have a carcass of a harness on ebay for GT125 Naked (new gen) like yours can probably be used to savlage connectors  and match things up with yours ?  (find us as @evocrest on ebay) –   Use this to repair the GTR harness as it requires a 2016 GTR harness (the one you have) , as  Gt125 Naked uses different switches and what not , but harness can salvaged to save yours ?
      • #11368
        Tom smart
        So just to confirm I need to go to ebay and find your page to order the loom from the gt125 naked and I can then piggyback the connectors from that loom straight onto mine and it should work? And in regards to the rest of the bike there are other issues I have that you may or may not be able to assist with. The other option would be that you mentioned about you repair looks etc, if I can manage to get sorted with guidance would you be open to the idea of me possibly sending my loom on up to you for you to have a look at yourself? Would like to explore the guidance route first however
    • #11377
      Hey Tom, buy these:
      Whart you want to do is , use the 2 harness looms to follow their wire colours and match them with your main harness.
      Then steal their connectors, to complete your harness to a good standard,  If you also pay now, I will do my 100% best to find you some spare connectors for the headlights too,  so you can make a bridge , but let’s worry mainly about getting the bike to work.   Don’t put the fairings on until it runs.   Keep her indoors! Weather is about to be brutal and will try to rust anything exposed to elements.
      I pray your brains and your hands will save her the cheaper way before resorting to sending me a loom to take a professional look (extra time added due to schedules possibly! – Life of a bike mechanic is fluid!)
      You can always do 1 picture at a time if you get stuck with a particular set of wires , and i will explain what those wires do.
    • #11884
      Tom smart
      My partner is going to order me parts for Christmas, I notice one has sold do you have another link for the required parts?
    • #11886
      Send me an email when she is ready and I will see what I still have left, but they do sell quickly yes as its that season everyone is fixing their projects up before spring time 2024
