How much time do you have? Looks like first things first is strip the tape away from all the looms to look for signs of burnt wires inside the tape jackets
Then go on Amazon, get this:
“MANNOL HARNESS TAPE”  about 6 rolls.
Let’s start with front to back.  We’re strictly going to focus on rebuild this loom here called “Dash Mini Bridge”
Strip it down carefully out of its black jacket (sometimes called back harness tape) , so you can look for breaks, sometimes it is the red wire that breaks inside.
Go back on Amazon and get this:
“9 Pin 2.8mm” connector with pins like this one below:
The dash side is called “FEMALE” end   (the blue connector in your pic i’ve mentioned above ^ )
Keep the male version for the main bike harness.
=========== NOTE! ===== If the big connectors are not broken, then skip the above connector i asked you to order.
Next , I can see that the speed sensor plug is missing  (GREEN, ORANGE, Black(?) , that i can see hiding behind the blue plug)
Get 2.8mm 3 PIN connector  both male and female
you want to make sure the “FORK LEFT SENSOR” on your front wheel has the same wire colours as the dash board wire, if unsure , keep posting images.
We got this , just follow as I say , you will get some life out of the bike  (we hope!) , as I will have to try my best to explain everything remotely over here without me having the actual harness myself to repair it.
