But yes the bike does have a kickstand switch and clutch switch how would I bypass these. So many useless things drives me crazy.
KickStand Switch = Cut it and join the wires at the harness side , and tape it very well, so it doesnt rust up or have water attacking it.
Clutch Switch = It is more recommended to replace it than bypassing it , as it may save you from “false neutral” starts , bike thinks it is in neutral when it is actually not, so if you press start , bike chugs forward and falls to the floor, and it may damage the flywheel sprocket due to extra strain on it)
For “testing purposes” , you can get use a metal paper clip , to join the 2 bullet connectors , to test for sparks.
